G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: jedimaster on December 12, 2006, 01:50:02 PM
Hi, I am having difficulties with Mastercam X and Mach 3. I see there are several choices for definition files and post processors to use within Mastercam X.(when you pick what machine there are 2 choices for 4 axis. Not sure which one to use.) I just can't seem to get the right combination. Once I import my .NC file to Mach 3, It changes stock size and doesn't position at the same zero as in the design. Can anybody help? The machine I am using is a Taig 4 axis mill (DSLS3000). Thank you.
Hi-
I'm having the same issues. I'm in the middle of trying different post processors right now.
Matt
