Mach Discussion => General Mach Discussion => Topic started by: komar1970 on August 13, 2011, 10:29:57 PM
Title: mach 3 driver test program
Post by: komar1970 on August 13, 2011, 10:29:57 PM
This line is not simple. pulse per second jumps. from 25,000 to 16,000 and sometimes as many as 4,000 to 15,000
jumps me all the time pulse per second
Please write me if this is the problem processor. my computer is ibm lenovo T61p
 windows xp pro
Title: Re: mach 3 driver test program
Post by: Hood on August 14, 2011, 04:14:46 AM
Laptops are notorious for having issues with the driver and that is why Artsoft does not recommend or support their use unless you plan to use an external controller such as the SmoothStepper, DSPMC, Galil etc.
Post by: RICH on August 14, 2011, 05:16:37 AM
The more stable / consistant the pps and closer to kernel speed is during the driver test the better. Wide swings like you are talking about says that particular pc will problematic. Example, my PC will consistantly be within 10 of the kernal speed and only varies by 1 or 2.
Post by: komar1970 on August 14, 2011, 08:20:24 AM
on other computers is the problem ok  but another problem in motor tuning I can not set step pulse to  2 i cen set to 1 , 3 , 5  but nat to 2 and 4
and also do not know what is the problem
Post by: Hood on August 14, 2011, 08:46:43 AM
Can yo attach your xml and I will see if I can replicate the problem and maybe find the issue.
Post by: komar1970 on August 14, 2011, 01:16:07 PM
that  is  for g540 gecko driver
http://www.geckodrive.com/ark-2/support.html?pid=15&id=89
Post by: Hood on August 14, 2011, 02:13:13 PM
I would need the xml that is on the computer you are having issues with to see if there are issues in the setup.
Post by: komar1970 on August 19, 2011, 07:07:48 AM
i have  add the  file
Post by: Hood on August 19, 2011, 07:15:09 AM
Ok you have sherline mode enabled, that means you can not set the pulse width as it is automatically set in that mode to achieve the widest ulse possible at 25KHz.
Post by: komar1970 on August 19, 2011, 07:21:15 AM
ok  i turn off sherline mode and is the  same nothing change
Post by: Hood on August 19, 2011, 07:25:39 AM
So your problem is you can not set puse width to 2 or 4?
I tried with your xml and its fine, in fact it was actually set to 2 fr pulse width a Dir was zero.
Post by: komar1970 on August 19, 2011, 07:33:22 AM
but why does it not shows me 2  only  shows me 1
Post by: Hood on August 19, 2011, 07:36:38 AM
please attach a screenshot of what you see as I  see as below with your xml
Hoo
Post by: komar1970 on August 19, 2011, 07:54:20 AM
i  have  only thet
Post by: RICH on August 19, 2011, 05:45:12 PM
You xml works for me....maybe its the screen your using.
Try it with the standard 1024 mill screen.
Post by: komar1970 on August 20, 2011, 08:07:17 PM
in other  computer is  other screen  and is the same
Post by: Hood on August 20, 2011, 08:08:33 PM
Well I dont know how it can be unless its a different xml you are using than you posted?
Post by: komar1970 on August 20, 2011, 08:10:22 PM
no  only  that
Post by: Hood on August 20, 2011, 08:11:35 PM
well afraid I dont have an answer for you as it works fine for me and also Rich.
Post by: Hood on August 20, 2011, 08:13:04 PM
What version of Mach are you using? May be that there was a problem with that at some point, dont recall ever hearing about such and issue though so only a wild guess.
Post by: komar1970 on September 08, 2011, 08:44:17 AM
the  mach 3  version  is ok  because  the mach3 in difrent  com  is working ok
