Mach Discussion => General Mach Discussion => Topic started by: Fastest1 on August 10, 2011, 05:03:09 PM
Can I run different kernel speeds on different profiles? I notice that I have quite a few profiles and some are running different kernel speeds. I typically run the default of 25 but want to use a higher speed on an upcoming profile I will be tuning. Is there any problem with doing this? For that matter, could I run 2 similar profiles with different kernel speeds and get faster travels with the higher kernel speed?
No problem at all as long as your computer is fine with the higher kernels :)
Also keep in mind, I believe you have to retune the motor tuning settings when setting different kernel speeds as well - ;)
Dave, I did assume that. I am just trying out some digital drivers. 5056D Keling
