Mach Discussion => General Mach Discussion => Topic started by: dfurlano on December 11, 2006, 06:25:38 PM
I upgraded to a newer computer. Did a fresh install of XP and the newest version of mach3 2.0.025 I was running 1.84. I moved over the XML file and downloaded the shuttlepro driver from the mach3 folder on the ftp.
Everything works except the dials on the shuttle. Buttons work fine.
Did a search on the archive to see if there was any reports of problems.
I re-downloaded the shuttlepro.dll and re configured still the dials do not work.
I never downloaded a driver for the shuttle so I do not htink there is any conflict of drivers.
I guess I can go down in versions to see if that will help but I thought I would ask first.
Thanks.
dan.
I have not had a chance to play with this yet. Does the shuttle pro emulate keystrokes? Could your screen set be causing this if it were different?
I had the incorrect driver. There is a download for the driver on the same page as the mach3 d/l.
My bad , works fine now.
Thanks.
Dan.
Good deal
