Mach Discussion => General Mach Discussion => Topic started by: ThomasCB21 on August 09, 2011, 11:54:19 AM
Hi folks,
I know this is probably not the place to ask. I have been asking questions and I have been getting my plans together. So my next question is, "Who know of a good and reasonable (cheap, cheap goes the birdy! :D ) vendor that sells L Type Gears? (these use a size 75 synchronous type belt)" As always any information is greatly appreciated and adds to my knowledge base.
Chris
Try MSG Industrial Supply as they may have plastic ones.
Heck, make your owne from bar stock borrowed from a friend and make sure you get the cutter to go with the stock! >:D
You did say cheap cheap ........ ;) :) :D ;D
Thanks Rich, I'll check them out. Say can I borrow some bar stock and the cutter? :D
Chris
Sorry Chris,
Can't lend you anything....my friends do all my programming and machining. ??? ;)
