Mach Discussion => General Mach Discussion => Topic started by: Workinforwood on August 07, 2011, 10:52:45 AM
Title: keyboard shortcuts
Post by: Workinforwood on August 07, 2011, 10:52:45 AM
I'm very new, so I know nothing. I was working on phone with a friend and he was discussing short cuts on keyboard. He said hit esc, that's same as reset. I hit escape nothing happens. He also said arrow keys, or page up down will control the mill head, but I try that and nothing happens. I did however get the pendant to come on screen by hitting the tab button. I guess I need the pendant to locate the machine zero, but by using the mouse and the pendant controls, I can't control the machine very well, like it moves down too fast and he says with the keyboard I should be able to be lowering the machine head a thousands or 2 at a time. Is the keyboard shortcuts something I have to configure somewhere? btw, the machine is Syil X5. Thank you.
Title: Re: keyboard shortcuts
Post by: ger21 on August 07, 2011, 11:18:44 AM
Escape is not reset, the key below it is. "~"
The arrow keys should jog the machine by default. However, if you have a pendant, you are probably in MPG mode. You'll need to switch to a jog mode for the keys to work.
You can change the jog keys using Config> Hotkeys.
Post by: Workinforwood on August 08, 2011, 01:20:58 AM
Thanx, I try that on Tues when get back home
Post by: Sailor10 on March 23, 2018, 09:51:22 PM
As we all know hitting the escape key stops motion, another function is that it re-enables Jog movements after an MDI movement of any of the axis's, which is a problem I am trying to resolve.  My keyboard is at one end of the machine and my pendant where I do a lot of setting up and work is at the other end of the screen.  I may enter in an MDI string to move the head, and then go to where I normally work, after the movement, I may want to jog the head to a different location, which I can't until I press the escape key at the other end of the machine.  I want to program one of the extra buttons on the pendant to emulate the pressing of the escape key on the keyboard.  Does anyone know the OEM code or how I may cause an event that looks and acts like pressing the escape key?
