Mach Discussion => General Mach Discussion => Topic started by: Rikk on August 01, 2011, 11:21:06 AM
Title: Microstepping on the driver...
Post by: Rikk on August 01, 2011, 11:21:06 AM
If I change the micro step setting on the driver will I need to redo the steps per in mach3?  if so I assume if I say go from 16 to 8, I could divide the current number by 8 and that would be my new steps per?
                 ...........Rikk
Title: Re: Microstepping on the driver...
Post by: angel tech on August 01, 2011, 11:38:09 AM
yes you will need to change them
Post by: ERP on August 01, 2011, 12:06:26 PM
you would divide by 2 not 8 in that case but yes you will beed to change them
Post by: Rikk on August 01, 2011, 12:30:58 PM
I'll dive in and have a play then, see if this fixes my little issue :)
