Mach Discussion => General Mach Discussion => Topic started by: renxiang on June 27, 2011, 06:13:19 PM
Title: Mach3 cannot send out signal
Post by: renxiang on June 27, 2011, 06:13:19 PM
Hello,
I have a problem, I connected the serial port to breakout board, but when I run Mach3, there's no signal sending out through the breakout board, nor the serial port. Any one knows the reason?
Xiang
Title: Re: Mach3 cannot send out signal
Post by: Hood on June 28, 2011, 01:56:00 AM
You need to use the parallel port rather than the serial port.
If you are using the parallel port then check you have the correct address set in Mach for it.
Post by: Tweakie.CNC on June 28, 2011, 01:57:27 AM
Post deleted - I totally misunderstood the question.
