Mach Discussion => VB and the development of wizards => Topic started by: Tony Bullard on June 24, 2011, 09:08:48 AM
In Ports and Pins / Output Signals I’ve got Output #1 enabled on port 1, pin 16 and have tried both Active Low and High.
I’ve run the following code from the VB Script Editor and a macro with the same results. The spindle LED lights and Output1 lights on the Diagnostic page. I can never get IsActive(OUTPUT1) to change state. It is always returns inactive or false. Any suggestions would be appreciated. Thanks, Tony
ActivateSignal(OUTPUT1)
Test = IsActive(OUTPUT1)
If IsActive(OUTPUT1) Then
Message "OUTPUT #1 input is active"
Else
Message "OUTPUT #1 input is inactive"
End If
Print Test
RTFM
"This function returns a Boolean True if the current state of the specified INPUT signal is its active state."
Don't worry, the reason I know the answer to your query is because I've been caught the same way.
Thanks djc,
so your saying Isactive() only checks the the state of INPUT signals and not output or leds?
Tony
Oops! I see it know. I have to use IsOutputActive() for output signals instead of IsActive(). IsActive is for input signals.
Thanks for getting me back on track.
Tony
