Mach Discussion => General Mach Discussion => Topic started by: angel tech on June 18, 2011, 12:21:29 PM
Title: z axis movement in machine coords.
Post by: angel tech on June 18, 2011, 12:21:29 PM
Got an odd one here, i need to move the z axis to -32 relative to the machine coords regardless of what offsets are in force. It's going in a toolchange macro to set the z height for the toolchange. Is there a G code to do this.?
Title: Re: z axis movement in machine coords.
Post by: Overloaded on June 18, 2011, 12:28:31 PM
G53 Z-32
Could it be this simple ?
Russ
Post by: Overloaded on June 18, 2011, 12:32:40 PM
Russ
Post by: angel tech on June 18, 2011, 12:37:34 PM
i tried that and it just added the 32 to the current z offset
Post by: angel tech on June 18, 2011, 12:51:14 PM
ah, i know why my try didn't work.
Post by: angel tech on June 18, 2011, 12:55:04 PM
to get a fast feedrate should i use a G0,
G53 G0z-32.00
or use a feedrate value
G53 Z-32 F1000
Post by: angel tech on June 18, 2011, 01:04:04 PM
the G0 does the trick.
Thanks.
