Mach Discussion => FAQs => Topic started by: jjanes on June 12, 2011, 03:23:32 AM
Hi everyone, just a quick question.What are some sources for bits especially ballend end mills I was thinking 1/8 - 3/16 shaft fairly small cutting diamter as my current focus is lithographs. My materials are nothing special just acrylic sheets from an 1/8 to 1/4 inch thick.
This is more of a general request though,most good sources would have what I need, I just need to find them.
You know, go with this good place; beware of this place kinda thing.
My cutting tool is a craftsman dremel so nothing to fancy yet unless anyone has a real inexpensive cutting laser for thin balsa wood handy they want to get rid of.
So what are your bit sources
Please help me out
Jeff
Don't take this as a dumb answer, but, anywhere and anyplace where you can find them at the cheapest cost you can get them for.
The 1/8" dia and small ballends get expensive and break easily.
I get mine on Ebay for about $5 each. For lithophanes, though, I prefer 1/16" or even smaller for best detail.
Thanks Ger21 I will look there
Thanks Rich, the reason I was asking was that the only places I have been able to find online varied significantly in pricing and the only local stores I could find at this point do not even carry the things I am looking for, Orchard, Lowes, Home Depot, so I was hoping for online examples.
The range I got for 1/8 shank diameter .02 cutting diameter with 2 flutes and a .06 cutting depth was between $12 and $40 both carbide is that normal?
Just do a search of all the places like MSG, JL, EMCO, etc and you will see that the corbide 1/8" shank with whatever diameter cutting end are not cheap.
I'm working on a small model and the feed rate and cut depth becomes important since as i said they can break in a heart beat. The Dremel tool has a fair amount of runout and that is just one thing that
helps break them. Some plastics or polymer material can be just as bad as metal or worst. I just bought a bunch on Ebay from different sellers to try out.
I guess what I was looking for was MSG, JL, EMCO or any other website urls I just do not know of many as I am just starting out.
on a separate note what is exactly meant by runout
Runout is the amount of deviation from a true reference line of a turning object.
So if you chuck that small end mill into the Dremel, and when it is turning, the wobble seen would be the runout.
So image trying to cut a line 0.020" wide with a 0.020" cutter and the end of it is actual wobbling around such that outside circle of the wobbly rotating cutter is 0.030".
thanks makes sense would one of those smaller bosch routers have less
Never had one, Gerry what do you use?
I use a Porter Cable 690.
You can get precision collets for a Bosch Colt from www.precisebits.com that have extremely low runout. I use them on my Porter Cable for 1/8" and smaller bits.
