Mach Discussion => General Mach Discussion => Topic started by: cooldude on May 25, 2011, 05:10:43 PM
I'm new to Mach3. I have a Taig machine with Gecko 540. My Mach3 read Gcode z1 and Zaxis travel 10 mm instead of 1mm.
It also does the same for X and Y axis. What have I don't wrong? I tried to use scale it 0.1 solved problem but when I tried to upload Gcode then the scale is off 1.00 again.
Is the drive are set to microstep
If you done the calculation for Mach3 for microstep (1:10) and the driver are set to single step (1:1), you'll get that result.
Jeff
Thank you very much. I got it fixed now.
