G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: chriscpmtmp on May 19, 2011, 06:53:39 AM
Title: 3d radius?
Post by: chriscpmtmp on May 19, 2011, 06:53:39 AM
Can Lazy CAM make a radius on the edge of piece I cut?  I'm not sure the buzzwords, but I think its a fillet or a 3d radius.  I'm pretty sure it can only do very basic 2d stuff, but I thought I'd ask.
Title: Re: 3d radius?
Post by: RICH on May 19, 2011, 07:49:14 PM
LC is 2D ........
Post by: RICH on May 19, 2011, 08:20:13 PM
You could generate the code by doing multiple offsets and applying the proper associated cut depth for each offset.
Much easier to have a program that does that for you.
Post by: chriscpmtmp on May 22, 2011, 03:35:44 PM
For the couple things I need to do, this might be the easiest way to go.
That aside, is there an easy (and cheap) CAM program that would be good for adding some radius cuts.
Post by: RICH on May 22, 2011, 07:08:06 PM
Try CamBam,
