Mach Discussion => VB and the development of wizards => Topic started by: ftec on May 12, 2011, 08:18:24 AM
Is it possible and how to run a macro from file when Mach loads?
/Risto
Not sure, but you can add it to the initialization string and run it the first time you press reset.
Wonderful workaround, thanks Gerry!
/Risto
HI,
If you are using a recent mach release, there is a script that is loaded (if it is present) whenever mach loads a screen set.
For more info get the programmer's ref manual from here
http://machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
and look up ScreenSetLoad.
Could be what I'm looking after, Thanks Dave!
/Risto
