Mach Discussion => General Mach Discussion => Topic started by: marcel beaudry on April 19, 2011, 02:55:38 PM
Hello
In the shapes wizzard when i try to input a cutter diameter of .125 it only rounds it up to .13 is there a way to change it so it accept a 3 digit number
thank you for your time
Marcel Beaudry
Hi Marcel,
The value that you enter is valid and accurate even though the DRO only shows 2 decimal places.
But if you want to change it, open the .set with Screen4 from the Mach3 folder/addons/shapes, double click the DRO and change the 2 to 4 (%+.4f)
Russ
... or, %+.3f for 3 decimal places.
That was fast
So if i input .1875 the program will use .1875 and put .19 in the box.
Thank you for your time
Marcel
Yes.
Well i thank you again for your time
Marcel Beaudry
Hey Marcel, I want to experiment with this a bit to be sure. I know I saw this before in another wizard but better check this one for sure.
I don't want to mis inform you.
You might have to change it as I mentioned earlier.
Russ
I'm not so sure about this one Marcel.
Whatever I seem to do, the final code produced is rounded to 2 decimal places.
Probably well suited for metric ops, not so good for INCH.
I'll stand by for a possible solution.
Proceed with caution.
Sorry,
Russ
Thank You
It works for me
Marcel
