Mach Discussion => General Mach Discussion => Topic started by: RAUL on April 14, 2011, 03:10:08 PM
Title: motors not turning
Post by: RAUL on April 14, 2011, 03:10:08 PM
NEW ON CNC - can  the stepper motors move when you install MACH3 DEMO?
I'm using C35 breakout board,a digital stepping driver and motors KL23H286-20-8b from KELINGINC ELECTRONIC  and I can't make the motor to turn,Help!!
Title: Re: motors not turning
Post by: Mishawaka on April 14, 2011, 03:38:37 PM
Does your controller need a specific XML file? My Gecko requires one for it to work.
Post by: RAUL on April 14, 2011, 03:48:37 PM
Thanks,let me look into?
Post by: Tweakie.CNC on April 15, 2011, 01:28:52 AM
Hi Raul,
Welcome to the forum.
The Mach3 demo version will work just fine.
Your C35 requires an enable signal to get any output - check that the EN terminal is connected to +5Volts.
Hope this helps.
