Mach Discussion => General Mach Discussion => Topic started by: Riley on April 13, 2011, 09:40:44 PM
Title: NPT Thread milling
Post by: Riley on April 13, 2011, 09:40:44 PM
OK....So how do I go about thread milling NPT? I did find a macro but it didn't run correctly, but I am new to this, could have been me. Have used the thread milling wizard with great results but have the need to run NPT threads quite often.
Title: Re: NPT Thread milling
Post by: Hood on April 14, 2011, 02:18:24 AM
 dont think the wizards can handle tapered threads so your best option would be CAM.
Post by: Speedtwin69 on April 14, 2011, 07:53:09 PM
The wizard will work if you have a NPT thread mill.
Post by: Riley on April 14, 2011, 08:24:00 PM
Thats a good point.....I will check into that.
Post by: BR549 on April 14, 2011, 08:34:25 PM
IF you  look on the manf sites for thread mills most have a wizard that can produce the threadmill code for both single point and multi point setups.
Also I think there is a programable macro in the mach tool box section for TMilling npt threads inside and outside.
Also I believe SheetCam has a threadmill modual as well, not sure if it does npt
