Mach Discussion => General Mach Discussion => Topic started by: rickdaniels on April 07, 2011, 04:42:47 PM
Title: Update did not overwrite old version
Post by: rickdaniels on April 07, 2011, 04:42:47 PM
Downloaded newest version of Mach 3 from Artsoft to a thumb drive.  Plugged the thumb drive into machine computer and double clicked on Mach 3.  Now I have two versions of Mach 3.  The old with all my configuration (licensed copy) and the new (licensed copy) with no configuration.  The forum suggest that when updating, the new version would overwrite the old and configuration would be automatic.  I have everyting backed-up.  Little help please.  Thanks
Title: Re: Update did not overwrite old version
Post by: Hood on April 07, 2011, 04:51:36 PM
Your old version must have been in a folder  or location other than the default or you chose to install the new version to a different location.
Simple thing is just copy the xml from the old folder over to your new folder.
Post by: rickdaniels on April 07, 2011, 05:22:33 PM
Yes, I believe the old version was in a folder which I have copied to a thumb drive in it's entirety.  There are several xml's in that folder.  Where is the default location of Mach 3 intended to be?
Post by: Hood on April 07, 2011, 05:30:59 PM
C:\Mach3 is the default location
Just copy over the xml for the profile you used, for example if you used the default mill profile it will be called Mach3Mill.xml
