Mach Discussion => General Mach Discussion => Topic started by: Samuelisaac on April 01, 2011, 03:37:04 PM
Hello, i am new here. I am retrofitting a Aciera f35 milling machine with mach3 and Granite. At this moment everything works fine and i made my first parts, but i have the following question:
Does anybody know how i can reset my servodrives (Granite VSD-XE with VSDEPI) in the mach3 programm? If i have a blocked servo due a failure mach3 stops all my drives (E-stop), but i have to reset my drives first in order to be able to reset in mach3.
Not 100% sure what you are asking but if its just a signal from Mach that you are needing then as long as you have a spare output you could make up a screen button to reset the drives if they fault.
Thank you Hood, I am gonna trie that!
