Mach Discussion => General Mach Discussion => Topic started by: Johnny Storm on March 21, 2011, 04:58:09 PM
Please someone know what is this: G90/91 State
Just means you are in the distance mode (G90 or G91) which is differs from your default mode.
Thanks hood, but how fix this ???
It doesnt need fixing unless I am mistaken in what you are asking.
What it seems to me is you for example may have Abs(G90) set as default for your distance mode but you have loaded code that has Inc (G91) for the distance mode. Mach is telling you it is not your normal mode, that is all.
As long as the mode is correct for the code then no problem :)
Thanks again Hood ;D
