Mach Discussion => General Mach Discussion => Topic started by: kolias on March 16, 2011, 10:48:42 PM
On Mach3 screen I can see the Tool Number I use but I dont see the diameter or the height as per attached picture.
Is this normal or I do something wrong?
Have you updated the tool table to fill the tool number, tool diameter and lenght.
Config, tool table
Jeff
Thanks Jeff,
No I did not because I thought since Mach imported the tool number from LazyCam (3) it should have imported the rest info.
So I guess I will have to update the tool info in both Mach and LC
BTW under Height is this the tools total height or just the cutting height (how much it extends below the chuck) ?
Normally, tool height is always taken from under the spindle to the tip of the tool
Same thing for any tool holder or taper type like BT-30, BT-40 or BT-50
But if you always measure your tools the same way, this not so important.
Jeff
Thanks for the info Jeff and the photos
That's a very nice micrometer you got. Can I ask where did you buy it
Would like that if it could be mine.
Those pictures are from the manual of MachStdMill.
Hope they don't mind.
Jeff
Jeff - As the author of MachStdMill, Thank you mentioning the software - positive word of mouth is nice to see. I don't mind small excerpts from the MSM manual (as long as credit is given for the source).
Nicolas - The height gauge in the pics is a Mitutoyo - it was a craigslist find a couple of years ago - a deal I couldn't pass up.
Some tips: Understanding Tool Length Offsets often starts with being careful about the wording used. The key letter in TLO is the "O" for Offset. The TLO value that goes in the tool table is an offset, which is usually NOT the same as the tool's physical length. That may sound a bit odd, but it's true.
The actual TLO value will depend on what technique you use to set Z0 for the part. If you'd like a good description of the topic, I humbly suggest the user manual for my MachStdMill software. The manual is a free download and there's a lot of info in the manual even if you are not using the MSM software. visit www.CalypsoVentures.com to get the manual.
And hey, if while browsing the manual, you decide to try out the software, you won't be first to take that path ;)
I didn’t know about the MachStdMill and visiting the site looks pretty interesting
I add it to my wish list along with the Mitutoyo gauge
Thanks Dave
Kolias, if its for tool length measuring off machine then maybe making your own height setter would be an idea. I made one, I used a glass scale at first but it broke so I ended up using an encoder and timing belt. It feeds direct into Mach and I can update the tool table at the press of a button :)
Heres a link to some pics. http://www.machsupport.com/forum/index.php/topic,10331.msg93511.html#msg93511
Since you're using a router, the easiest thing to do is make an auto zero touch plate. Costs about $1, and you never need to mess with the tool table.
Unless you have a spindle with an automatic tool changer, you can't really measure your router bit's length anyway, until it's in the router.
Hood I like your Beaver and all work you did, but most I liked the nice control panel (screen and keyboard) but you never posted a picture of it painted (unless I miss it)
Gerry I do have an auto zero touch plate, works really well and I love it and that is enough for me.
My original question on this thread was about the tool info screen on Mach which only shows the tool number but not the diameter and height. Basically I dont need this info since I dont use that many different bits although it would have been convenient to have
Just trying to make sure you don't buy something you don't need.
Thats probably because its still not been done, maybe one day ::)
