Mach Discussion => General Mach Discussion => Topic started by: zaki on November 22, 2006, 02:00:25 AM
Hi Guys
I have a cnc mill Bridgeport Series 1, the controller is dameged during traveling. Can I convert that machine into CNC again by this Artsoft??
I have done it, see here http://mysite.wanadoo-members.co.uk/hoodsmachiningpages/Series1Retro.htm
What version of mill do you have, mine was a BOSS 6.1, does yours have servos or steppers?
Actually I have both machines here. I Just want to know what will I need to make machine 100% ready? Can I install it by my self? or it needs some expert personell? Is it runs on just G codes? what kind of pc I will need?
Hi
I've also convert my Bridgeport Series 1 Boss 6.1 with steppers, I used all the original drivers and motors, just changed the control.
There is quite a few people done this, have a shearch on CNCzone you'll find quite a few threads about doing it like this one http://www.cnczone.com/forums/showthread.php?t=24314
You should be able to convert the servo version to but that will be a bit more complicated.
Chris
Hey,
You won't need any experts. If you do, they are on here. I have a bare bones Dell Dimension B110. It works great.
Hey Chaoticone
thanx dear 4 ur reply, how many serial or parallel ports will I need? by with means computer will connect with motor drives etc???
You can use one or two ports, I have two in mine but if you just have limits and drives you can get away with only one port.You can use one limit switch per axis and configure it to be a limit for + and - and also it can act as a home switch when doing a reference move, this will save greatly on inputs needed.
Bundle of thanx Hood
I am still looking for more replies and views :o
Another thing I think is neat is an Ipac keystroke emulator. It hooks either to a ps2 connection or a USB port. With the Ipac 4 you can add 56 inputs. You set it up in Keygrabber.
http://www.ultimarc.com/ipac1.html
Not sure if I remember correctly but I seem to recall that the USB versions didnt work too great in Mach so best sticking to the PS2 versions to be on the safe side, I have one and it is great for adding physical buttons ;)
that means I dont need any additional IO card or anything. Just I need Mach3 and thats all?? This is what I understand. Is Mach comes with all detailed instructions to install the software and machine??
What controller do you have on the Bridgeort at the moment, is it the BOSS series? Is the controller working?
Its Heidenhann TNC150 and not working.
OK so do you know what is wrong? Totally knackered? If you have to replace the complete control hardware you may be able to use the rutex drives with your servos.
I have some pics of a bridgeport that i removed a heidenhann tnc 150 from and replaced with gecko drives and mach3 if interested.
Joe
Hey Joe,
Post those babies on show and tell. No wider than 800 pix. JPEG formatt. We like sexy photos. ;D
Thanx guys
n we all like to c those sexies ;D
