Mach Discussion => General Mach Discussion => Topic started by: kolias on March 09, 2011, 05:28:26 PM
Title: Break-in Wizard Problem
Post by: kolias on March 09, 2011, 05:28:26 PM
I was planning to do my 1st cutting this morning but was not able because of the new developed problems.
I installed the new screen set which Russ gave me and then run the machine a few times with the keyboard, then home it a few times, run the auto tool zero a couple of times and all was normal.
Then I run the break-in wizard a few times and that was also normal. Then I opened the gcode of the break-in wizard and changed the –Z parameter from -3 to -2 and also changed the Y and X axis max distance and the feed rate and run again the wizard
Normally when the wizard starts it lowers the Z to my setting and then homes the X and then the Y. In my case, the Z was ok but on the X it skipped the line G1X0Y0 and jumped to the next line G1X29 and of course since the machine was not homed when the X axis reached the + limit she stopped.
Trying to fix this problem I don’t know what I did but the limits went from active high to active low and the X & Z limits were not even working. Anyway I fixed the limits with the “automated setup of inputs” and that fixed the limits and now all is normal again.
However the wizard still skips the line G1X0Y0 and jumps to the next line G1X29, Anyone knows what is wrong?
I attach the wizard here for info
Title: Re: Break-in Wizard Problem
Post by: Hood on March 09, 2011, 05:46:08 PM
The code doesnt actually home, it moves to X0Y0 but that is offset coords and not machine coords so it will be where ever you have the offset zero set. Could that be your problem?ie you are already at X0Y0 in offset coords?
Post by: kolias on March 09, 2011, 06:22:40 PM
I have not touch or set any offset coords. When I start the wizard the router is about in the middle of the machine, I always did that and worked before
I know that the code doesnt home but it takes the X and Y almost to home first and then to the other end of each axis (+) and back. In my case it skips the code line X0Y0 (I can see it in the code window) and starts to move to wards the X+ and it trips the limit.
Is there anything wrong the way I input the values on the wizard? These values are shown at the top of the code
Post by: Hood on March 09, 2011, 06:28:04 PM
Ok but if you press Zero at an axis DRO you have just set an offset. Normally you would see this but if you just happen to have the machine coords on view then you will not see the zero position.
Code looked OK from the quick glance I had.
Post by: kolias on March 09, 2011, 06:40:02 PM
Thank you Hood, I will try again tomorrow to see if I can find anything
I must be doing something wrong because I did run the wizard earlier and all was fine. It all started after I changed the wizard parameters by editing the code instead by running the wizard and change the parameters there. Perhaps thats the problem
I will try tomorrow both ways
Post by: Hood on March 09, 2011, 06:47:18 PM
If you cant get it attach your xml and I will see if I can find something.
Post by: kolias on March 09, 2011, 06:52:53 PM
Thanks, I will do that if I run into problems
Post by: Overloaded on March 09, 2011, 08:34:17 PM
Hey Nic,
 I think you should HOME your machine first, then while it is still HOME, ZERO the axis DRO's. (or, if you are using the G54 offset, select another offset, then zero).
  Make the entries in the wizard .5" shy of the full length of the axis travel. Be careful with the Z direction !
The code will be in WORK coordinates, not machine coordinates but for this, they should be one in the same.
Russ
Post by: kolias on March 10, 2011, 11:14:01 AM
Russ I did what you say but it has no effect on the wizard. No matter where the router is when I run the wizard, it says to put the Z to safe 0 and then it will take the X & Y axes to 0 position and then it will continue
All went fine this morning, run the wizard a few times with no problems and did a simulated run (Z at +2” from top of material) of the pattern I want to cut next but have one question
When I’m ready to cut, I move the router where I want to start my cut, then 0 the X & Y and then I use the Auto Tool Zero to set the Z axis. After the tool finishes its program it goes up 1" and it stops and the DRO for the Z reads +1.0000. (my rapid height is set in LazyCam at 1” above the material)
My question: do I leave the Z axis DRO as it is or do I zero the DRO and then start my cut?
Post by: Overloaded on March 10, 2011, 12:27:05 PM
Looks like you got the wizard figured out ... great ! :)
If you did as I suggested, it would already BE at Zero. ;)
My question: do I leave the Z axis DRO as it is ........
Yes, leave it as it is. After you run the Auto Tool Zero routine you should be good to go, assuming you touched off from the top of your material of course.
Start with a slow feedrate and stand by the EStop just in case though, it will be dependant on the script in the macro.
Post by: kolias on March 10, 2011, 12:48:18 PM
Thanks Russ and BTW thanks for the screenset you sent me, makes life much easier for me
I think I should not change the DRO after the auto tool zero finish its job but I'm not sure about the script
Here it is if anyone can tell me if its good to go
Post by: Overloaded on March 10, 2011, 01:04:30 PM
 ??? try again  ???
Post by: kolias on March 10, 2011, 02:19:22 PM
Sorry .............
For sure now LOL
Post by: Overloaded on March 10, 2011, 02:41:01 PM
Looks good from here Nic..
Works fine here in simulation too.
Have FUN !
Russ
Post by: kolias on March 10, 2011, 02:45:08 PM
Thank you Russ
Post by: kolias on March 11, 2011, 07:31:26 AM
Cant put to bed the subject of limit switches and it gets very frustrating.
As you can see this happened to me before (my first post here) and I have got to know what the problem is.
This morning I was planning to start my first cut. So I turned ON the computer and then opened Mach. Then I turned ON the CNC and I got this message “Your reset command is failing due to an external reference....” and at the bottom of this message it says “Fix this for me, toggle any active switch settings”
Now on the diagnostic screen all limits LED’s are ON and I know that if I click the above message it will put all my limits to active low and that’s no good because I did click it and the LED’s went out on the diagnostic screen but now when I press the limits manually nothing happens, I mean I see no limit switch triggered message neither any LED light up on the diagnostic screen.
Anyone knows why this happens? I attach my XML here but remember that I have clicked the message above and all limits are now active low and they don’t work
Post by: Hood on March 11, 2011, 08:01:24 AM
Something is bad, whether wiring, bob, cable or port I dont know. Test with a meter to see if there is voltage getting to the switches.
Post by: kolias on March 11, 2011, 08:54:45 AM
I'm at lost too, checked everything and all is ok
I reboot the computer, reset the limits with the Automated Inputs Setup from the inputs screen and now all is ok again and I will do my 1st cut with my finger on the EStop LOL
Thanks Hood
