General CNC Chat => Show"N"Tell ( Your Machines) => Topic started by: Hood on March 05, 2011, 10:19:18 AM
Title: Thrown together coil winder ;)
Post by: Hood on March 05, 2011, 10:19:18 AM
Have a big Aluminium welding job on at the moment and ran out of wire and the local stockists didnt have any of the 100mm dia rolls that I use in the spool on gun. I bought a big roll and started winding it onto the small rolls on my Triumph lathe but it gets boring and results are crap. Decided I could make up a couple of brackets for the front  turret in the Computurn  lathe and use my small winders screen and set up a new profile.
This is the result, its rough and not perfect winding but it will get me out of a scrape and with a bit of tweaking it will work well. :) Add to that the fact I get 20 wee rolls out of one big one, the big roll costs £47 the wee ones £7, so quite a saving if I dont have to constantly watch over it (dont tell my customers though ;D )
Title: Re: Thrown together coil winder ;)
Post by: Tweakie.CNC on March 05, 2011, 10:47:21 AM
Now that's what I call Scottish innovation.  ;D
Post by: Hood on March 05, 2011, 11:52:06 AM
You trying to say I am a tight bas%^$£d?
;D
Post by: RICH on March 05, 2011, 02:11:45 PM
You got that idea from using the sewing machine where the big bobbin of thread is used for the whicha ma call it inside the sewing machine.  ???
Cheap no ........adaptive..... yes   ;D
Post by: Hood on March 05, 2011, 02:47:32 PM
Ha ha nope, got the idea from needing the wire on the small spools for the migs spool on gun, and only being able to get a large spool :)
Alu mig  welding is a PITA if you have to feed the wire over a long distance and even a 3m torch can be a pain if you are twisting and kinking it. The spool on gun means I can get 10m away from the wire feed unit but the wire still only has to feed about 150mm  :)
Post by: Tweakie.CNC on March 06, 2011, 03:43:18 AM
Hood,
I have not seen the spool on gun before, looks like a brilliant tool.
Do you have to have a special drive unit / power unit to supply the power for the wire drive motor in the gun ?
Post by: Hood on March 06, 2011, 04:43:00 AM
There are several variants of spool on guns, my previous one required that I fit a PCB inside the wire feed unit but I now have one that has an inline control box so only requires a standard Euro torch connection on the wire feed unit. That means I can swap from machine to machine without having to mess around wiring in a PCB.
Here is a link to the one I have, although I never got from that supplier, its just they have a pic of it.
http://www.migtigarc.co.uk/MIG_Welder/MTA_SGS360_Spool_Gun/mta_sgs360_spool_gun.html
and in the pic attached I have arrowed the control box.
Post by: Tweakie.CNC on March 07, 2011, 01:08:53 AM
Thanks for the info Hood, much appreciated.
Post by: ostie01 on March 07, 2011, 06:22:56 AM
Surprise me that no body have not yet asked if it can dispense beer. ;D ;D
Jeff
Post by: Tweakie.CNC on March 07, 2011, 06:56:09 AM
Methinks you are taking the P Jeff  ;D
Post by: Ya-Nvr-No on March 07, 2011, 07:37:46 AM
That is a beautiful wide secure fire door Hood! :-)
Post by: Hood on March 07, 2011, 09:18:09 AM
Well I dont drink but this bloody wind and trying to weld Alu is close to making me contemplate seeing if it can dispense alcohol but think it will be something stronger than beer :(
Post by: Hood on March 07, 2011, 09:21:43 AM
Funny you should mention fire, just sh$t myself 10 mins ago as I forgot it was alarm test day and I was just coming in the door when it was switched on, cant be certain but I think they maybe were watching me on the security camera  and waiting for me to come in ;D
Post by: Hood on March 07, 2011, 09:53:36 AM
Heres a pic of it without the coil fitted, need to make up a friction pade so the big roll is under tension and the front part will have to make up a PTFE nozzle as the copper contact tip it heating up and grabbing and shaving the wire at any faster than 400rpm. Also thinking of making a pressure flap that sits on the small coil so the wire is held on the coil as it gets wound as it may help stop it wanting to jump as it reaches the end.
Post by: Gridley51 on March 08, 2011, 07:50:25 AM
I can see the floor in the welding shop.That`s a first.:D
Post by: Hood on March 08, 2011, 08:05:45 AM
That was 2 years ago ;)
