Third party software and hardware support forums. => SmoothStepper USB => Topic started by: OzzieII on March 01, 2011, 02:17:31 PM
Title: Max Servo speed
Post by: OzzieII on March 01, 2011, 02:17:31 PM
Is it possible for SS to drive a servo motor at a speed greater than the nameplate RPM, without raising the voltage?
Ozzie
Title: Re: Max Servo speed
Post by: ger21 on March 01, 2011, 05:03:24 PM
A servos rpm is proportional to voltage. I don't think the motor would last long, if you provided more voltage than it's rated for. I've read that you really should design to run at 80% of the rated rpm.
The Smoothstepper just sends step and dir signals, and can only have it go as fast as you have your motor tuning set.
