Mach Discussion => General Mach Discussion => Topic started by: forrestcarve on March 01, 2011, 10:56:25 AM
I am new to CNC. Have had a MAXNC router for about a year now and can't get it running. The manufacturer has gone out of business, so I can't get any help there.
The problem I am having right now is when I transfer a program from V Carve Pro to Mach 3, the G code loads OK. But when I attempt to run it I get an alert down by the reset button that says "NESTING COMMENT FOUND LINE 1" and the program will not run.
Everything in V Carve pro seems to be fine.
Have never been able to get this #*^# thing to run and am hoping that some kind sole out there can help me. Any comments on this problem would be greatly appriciated.
Forrestcarve
A nested comment is a comment within another comment.
Like: (Filename: Block (Pocket) Rotary.tap)
Remove any extra parentheses and try again.
Are you using the proper Post processor from Vectric ?
Hi Overloaded,
You were spot on my " nested comment prolblem. Thank yoy Sooooooo Much.
Forrestcarve
Great website because this website provides us complete solutions of class 7th Science subject for free. solutions for class 7 science NCERT (https://fullncertsolutions.in/category/class-7-science/)
