G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: kolias on February 15, 2011, 08:22:16 PM
Regarding my post “Interface Tutorial” under General Mach Discussion I would have liked to know if LazyCam can do the same as the “Multipass Wizard”
It looks like that if I set my tool parameters in LC and set the Max Depth per Cut to what I want and then set in the Cut section my cut depth, LC seems to do multipasses to cut my piece.
Is there any difference between the Multipass Wizard and the LC procedure I described above?
Any pros / cons between the two?
Nicolas,
Two completely different programs even though they do a similar task. Can't really compare the two.
Thanks RICH, I thought so but wasn’t sure
Soon I will try both on a small project to see the difference, just to learn
