Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: OCNC on February 02, 2011, 06:27:40 AM
I'm wondering if there's a simple way to get the bounding box for any lettering produced via the Write wizard.
More specifically the easiest way to come up with the bounding dimensions.
Thanks.
Chris
Hi Chris, welcome to the group ! :)
You can set the text start at 0,0 in the wizard, then post the code and look at the Program limits in the ToolPath screen.
Hope this helps you.
Russ
Got it. Thanks Russ
Russ
