Mach Discussion => General Mach Discussion => Topic started by: slinghit on January 28, 2011, 10:59:38 AM
Title: Wizard Error
Post by: slinghit on January 28, 2011, 10:59:38 AM
I incorrectly entered a bad input into the Spline and Gear Wizard and saved the value.   Now I can't reset the error.  I keep on getting "Error Rapid Plane <=0******. "E Stop button Pressed"   I have since then entered a value larger than zero but the error will not go away.   Can you help?
In addition, I have disabled the E-Stop in the Pins and Ports but it keeps on enabling itself.  I hit apply after making change.    This is a very small machine and the E-Stop is not really needed for the stepper motors.
Thanks for any input.
Jay
Title: Re: Wizard Error
Post by: Overloaded on January 28, 2011, 11:19:17 AM
Jay, the estop is permanently enabled as a safety feature, just change the active state and it will then work.
Will look at the wizard later, or someone else will chime in.
Post by: Overloaded on January 28, 2011, 11:29:18 AM
Dont forget to hit enter after changing a DRO, then click Post code to clear the error. If your new value is valid of course.
Post by: stirling on January 28, 2011, 11:31:47 AM
As above - It seems it's just the error ticker isn't correctly reset - just ignore it. Just enter a correct value and post the gcode.
Ian
Post by: slinghit on January 28, 2011, 11:40:25 AM
I hope I am not asking too dumb of questions.
I assume that changing the active state for the E-Stop is disenabling in Input signals?
I thought I had entered the correct value and posted code but the error still will not go away.  I will try again when I get home tonight.
I really appreciate your input.
Thanks Jay
Post by: Overloaded on January 28, 2011, 11:56:05 AM
No, leave it enabled, just change the Active State under the active low column.
Post by: slinghit on January 28, 2011, 11:59:32 AM
Thanks, Overloaded!!
