General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: michaelthomas on January 24, 2011, 10:46:02 PM
I made some rack and pinion reduction drives for my new project.
6061 aluminum with 120/19 Gates GT2 3mm belts and pulleys. Final ratio is 6.32, and after the 20 tooth rack gear I'll have about .50 IPT.
It's a Nema 23 setup. :)
Very nice work Michael.
How are you getting the tension on the drive belt ?
Well.....the first design had an idler that also put more wrap on the small pulley. It turned out to be unnecessary and just added a lot of drag. The belt maintains 7 teeth engaged without the idler, and is adjusted by slotted mounting of the stepper.
Nice craftsmanship!
