Mach Discussion => General Mach Discussion => Topic started by: LB on January 12, 2011, 07:04:33 AM
Title: Mach 3 and CorelDRAW.
Post by: LB on January 12, 2011, 07:04:33 AM
Good Morning,
I have been using BobCad v21, but we are switching everything over to CorelDRAW.  We are having problems with Mach 3 "reading" the CorelDRAW programs.  What do I need to do???
TIA for any suggestions.
LB
Title: Re: Mach 3 and CorelDRAW.
Post by: Kerry Harrison on January 12, 2011, 08:30:52 AM
If you're planning to use CorelDRAW to create DXF files as you have discovered this works poorly.
To solve this problem I use a simple program called DXFTool. This program is a plugin for CorelDRAW and it creates excellent DXF files from CorelDRAW drawings. After the files are exported with the DXF tool I can open them in AutoCAD if I want to make further refinements, or go right into SheetCAM to set up the tool paths etc. Then the G code file that Mach3 needs is created using the post processor in SheetCam
DXFTool is found here - http://www.coreldrawtools.com/
SheetCam is found here - http://www.sheetcam.com/
Kerry Harrison
Post by: LB on January 12, 2011, 08:41:02 AM
Kerry,
Thank you for the information.   The only reason we switched was, we were told by several CNC users in the area, that CorelDRAW was much easier to work with.    Hmmmmm, I beginning to wonder........
LB
Post by: LB on January 12, 2011, 11:44:23 AM
Instead of using SheetCAM, would I be able to use Vectric Cut2D?
Lu
Post by: Kerry Harrison on January 12, 2011, 11:15:26 PM
Yes.
I have not used Cut2D but from what I see on their website it has more features then SheetCAM. Seems like downloading the free trial would be the next step.  :)
It would be interesting to see how well it handles a dxf file created by Corel without the DXFTool. Don't know if you have Corel but if so I would try that before buying the DXFTool.
Just some personal thoughts on CorelDRAW. I use it because we run a printing business as well as a machine shop and have used Corel since version 3 so I am very familiar with it. For graphics work making things like signs and especially for projects with text it's great. However for machining projects that require a high degree of precision I find AutoCAD is a better choice.
Kerry
Post by: Tweakie.CNC on January 13, 2011, 03:43:27 AM
Kerry,
Do you use the standard DXF Tool or the Professional version ?
I am thinking that at $190 the professional version does seem a little steep.  :-\
Post by: LB on January 13, 2011, 05:28:50 AM
Kerry,
I am going to download the free trial of Cut2D today.  My boss purchased the DXFTool yesterday.  He got the professional version.
Several month ago, we were having problems with our CNC machine, so we had to out source our work to another company.  They used CorelDRAW for their program for our items.   It worked great for them.  Sadly, they did not inform us of everything we would need to get our system up and running.  And still won't share any of their "trade" secrets.
I will say tho, that CorelDRAW is so much easier to use than BobCad V21 for drawing out the plans.
Tweakie, we got the professional version because it offers so much more than the standard version.  That way if and when we expand our work load, we will already have the better program.
Thanks for all the information.
LB
Post by: Kerry Harrison on January 13, 2011, 08:11:28 AM
Tweakie,
I use the standard version.
Kerry
Post by: ger21 on January 13, 2011, 10:46:10 AM
Lu
Yes, you can use any CAM program. The key is the DXF Tool to get a usable .dxf file
Post by: LB on January 17, 2011, 05:29:32 AM
My company is going to purchase Vectric Cut2D.  Would it be wise to bundle our package and get the Cut2D and Cut3D?   What would be the big advantage to Cut3D?  The difference in price is $250.00.
TIA for any information.
LB
Post by: Tweakie.CNC on January 17, 2011, 05:43:28 AM
LB,
I think that Cut3D would be great if you are going to want to produce 2.5D or 3D models.
(http://www.vectric.com/WebSite/Vectric/cut3d/images/F1_car.gif)
Post by: LB on January 17, 2011, 06:30:02 AM
Hi Tweakie,
That is what I thought.  But, I wanted someones professional opinion.
Thanks for the reply.
LB
Post by: rrc1962 on January 17, 2011, 08:16:25 AM
LB
Cut2D does not have a lead in/out feature, which makes it virtually useless for contouring, unless you're OK with start and stop divits.  Doesn't make much sens as they advertise the software for contouring.  Sheetcam is a much better option.  It is far more flexible than Cut2D.
Post by: rrc1962 on January 17, 2011, 08:42:49 AM
Corel is a graphic arts program, not a CAD program.  You can jump through some hoops to get an acceptable DXF output but personally, I find it much easier to just use the right tool for the job.  I have AutoCAD, Rhino, Corel and Illustrator.  My order of preference for CAD drawing would be Rhino, AutoCAD and finally (reluctantly) Illustrator.  Notice I didn't mention Corel.  I despise Corel.  The only reason I have it is so that if someone sends me a Corel file that won't import into anything else, I can open it and export it as something that will.  i think I've used it twice in three years.
Post by: Tweakie.CNC on January 18, 2011, 07:03:22 AM
I agree and think SheetCam is a much better option here but to be fair Cut2D does have a 'ramp plunge' option which does prevent 'divits' (assuming you have a machine with minimal to zero backlash of course).
Post by: rrc1962 on January 18, 2011, 07:51:50 AM
Depends on what you're using it for.  I think most people who have a CNC router have more in mind for their machine than just simple contouring.  The only machine that is really made JUST for contouring is plasma, laser or waterjet and those operation require a lead in/out.  Ramp plunge won't do anything there.  I think Cut2D is basically a low priced "get-you-in-the-door" program to make new router users realize they need more.  If they added lead in/out capability, they would probably develop a loyal plasma user group.
I also tried it for contouring MDF on a router and while ramp plunge was better than a straight plunge, the entry/exits were not as clean as a arc ramp in/out.
IMO, if you need 2D profiling and pocketing only, go with Sheetcam.  It's more powerful and cheaper than Cut2D.  If you need 3D feature machining and v-carving go with V-Carve Pro.  V-Carve Pro is basically ArtCAM Pro at a fraction the cost.  I can't figure out how they were able to knock off ArtCAM so closely without raising some eyebrows unless (1) Vectric was formed as a "low end" division of ArtCAM as to not devalue their premier product or (2) The guys at Vectric had some ownership in ArtCAM and were able to leave and take their ideas with them without a non-compete.
Post by: Tweakie.CNC on January 18, 2011, 10:07:08 AM
Ahh plasma - I do not recall plasma being mentioned in this thread, come to think of it I don't recall Cut2D ever being advertised as being suitable for plasma either - certainly not by Vectric. But I can see that 'ramp plunge' is totally useless for plasma work compared with 'lead in'.
Post by: rrc1962 on January 18, 2011, 11:26:14 AM
My 1st point was that the only folks who ever really need 2D contouring exclusively are plasma users.  It doesn't take long for a router user to realize that their machine can do a whole lot more than just cut 2D contours.   You're right, Vectric does not advertise Cut2D for plasma.  In fact, they will tell you that it's not suitable for plasma at all when the only thing needed to make it suitable is a lead in/out function.  My 2nd point was that if they did add lead in/out they would sell more copies to plasma users than router users.
I'm not bashing them.  I like their software and was very disappointed that I couldn't use it.  I understand from a marketing perspective why Leads are not included in Cut2D, but really, this is a basic function when it comes to contouring.
Post by: Bob La Londe on January 18, 2011, 11:45:58 AM
I have Corel Draw and I used it briefly for parts designs.  It worked ok, but was limited to .001 precision.  It rounded numbers with a higher precision than that.  For most parts cutting at a precision of .001 is more than adequate, but the problem I found with design was that the error could be cumulative will moving, copying, centering, and other manipulation of drawing elements.
Now if I could set it (or if I can somebody would tell me how) to about 6 digits of precision while drawing that would be fine.  My machine when freshly adjusted only does about .001 precision and .0005 repeatability anyway.
Yes.
Kerry
Post by: Joseph on January 18, 2011, 12:01:41 PM
Hi Bob,
I've never checked the accuracy, but if you go to Tools/Options/Workspace/Edit you can change the precision.
If you check it out let us know if it really makes a difference.
Post by: Bob La Londe on January 18, 2011, 12:13:57 PM
I may, but lately I have been using ViaCad more and more.  I may need to look into another 3d Cad though.  I am starting to run into the limitations of ViaCad.   For most 2D stuff I design it right in CamBam anymore.  Some stuff it doesn't do well, but it makes arcs and lines just fine.  You can even do 2d work and rotate it in 3D to some extent.
Hi Bob,
Post by: adprinter on July 27, 2011, 12:23:41 AM
I have been using Corel Draw X3 for creating all drawings. And like others here, discovered that Corel's DXF export is pretty much useless. However, I have discovered that exporting the drawing as a HPGL *.PLT file will preserve the proper scale, and makes it possible to load the file into LazyCAM for toolpath creation. Just use LazyCAM's Open Vector File, and scroll down to choose the HPGL.PLT format. I too tried the trial DXF tool software, but after discovering that Corel Draw already had the capability I needed, opted to just export as *.PLT files. The important thing to pay attention to, when creating your drawings is to use the Snap feature, and some experimentation is needed in LazyCAM's tolerance settings to join lines into a single entity when cutting pockets, or profiles. All of this "Work-Around" has made my decision to purchase a dedicated CAD/CAM (BobCAD/CAM v24) and the related learning curve involved as soon as I could afford the price. Am just now starting to learn BobCAD/CAM, but I have already come to realize, that it all depends on what you are trying to do. So the future looks as though it will continually involve the use of multiple programs to achieve a given project. I built a 4-axis CNC Router table, and (depending on the job), create toolpaths by using Corel DRAW, WoodGears, CNC Wrapper, and now BobCAD/CAM. Vectric's Aspire software looks promising as a single program to do it all, but is simply not within my means (yet). -Just my 2 cents worth
