Mach Discussion => General Mach Discussion => Topic started by: Phase on January 05, 2011, 10:13:16 PM
Hi, I just wanted to highlight what I think is a small bug and perhaps provide enough information that makes fixing it easier. Thanks!
Mach correctly saves changes to the G73 retract setting one defines under "Config>Ports & Pins>Mill Options"
However, when it starts up again it fails to read the saved settings and defaults it back to 0.1".
The issue being that since the retract is only to break the chip the 0.1" pull back is rather large, and a value of 0.01" with no dwell would be much nicer in certain cases.
Are you running in demo mode?
Don't think so. It is a licensed version and that is in the machine I normally use it in.
Just as a note I can confirm this here as well.The value does not stick .
Hi, here is a video with the 0.01" pecking retract -- first operation in the video. Perhaps this would help make a case to release a new version where the setting is initialized from the XML as opposed to always defaulted to 0.1" :-)
http://www.youtube.com/watch?v=4Cfh2yQZwK4
Thanks.
