G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: cpayne on January 04, 2011, 06:15:09 PM
Im trying to create an offset, on the far right end of the drawing but cannot seem to find anything to make it work. I am trying to use an 1/8 endmill to do the entire part so I dont want to change tools. The slots are suppose to be .125." I have changed the tool diameter and the size of the slots but cannot seem to find a way to get them all to work. They are identical parts but only two of the eight slots are being offset. Any tips on this? I have tried changing the tolerances as well
Seen this before on multiple slots and here is an easy work around. In CAD just draw a line representing the center to center of the slot and maybe put it on it's owne layer.
Then just select that layered name in LC, pick any tool dia with a defined max depth and set the depth of cut. You will get what is shown in the pic.
Sure beats trying to get them to all work. ;)
