Mach Discussion => General Mach Discussion => Topic started by: monkeyevil on December 16, 2010, 06:54:12 PM
Title: Running mach + other apps = errors...
Post by: monkeyevil on December 16, 2010, 06:54:12 PM
I currently have a PC with a 2700 AMD 64 running at 2.2gHz, 2GB of ram, Windows XP 32 Pro. Running Mach3 R3.042.029.  It's a plasma table using hardware from C&CNC (PlazPak-1A)
While running a program I can have Mach and Sheetcam open simultaniously, and I can switch between both programs, screens in Mach, or draw sheets in Sheetcam while cutting with no issues.
If I open a browser window while cutting Watchdog is usually instantly triggered. If I open the window while not cutting it's hit or miss if Mach will go into reset.
Currently I'm trying to run a webcam so I can watch the table while sitting in my office.  I'm running the smallest cam software I can find, maxing out at maybe 25% cpu usage on just that software.  At best everything goes fine, at worse the table starts having random movements + torch fires when running the cam. (With Watchdog turned off)
Ideally I'd like to run both the webcam and a remote desktop software... but at this point that may be asking a lot.
Any ideas?  I just updated to R3.042.040, but I can't currently do any webcam testing as I'm trying to actually get sheets cut.
Thanks!
Title: Re: Running mach + other apps = errors...
Post by: RICH on December 16, 2010, 07:03:33 PM
Suggest you dedicate the machine strickly to running Mach and don't be fooling around with other stuff on the PC when controlling a machine with it.
Post by: Jeff_Birt on December 17, 2010, 08:24:52 AM
I would like to ditto what Rich said. Mach has to depend on VERY precise timing to work properly. Depending on your PC configuration (motherboard, memory, video card, etc) opening up a browser can place a huge load, (maybe just a second long), on the system. This obviously will throw Mach for a loop. One way around this is to use a motion control card to offload the more timing critical things from Mach's parallel port driver (SmoothStepper, Galil, KFlop, etc). This will free up a lot of processor time on the PC but there is still no free lunch. You still should not try to do things like run files from a thumbdrive or network drive as they are too slow and will cause problems.
Post by: monkeyevil on December 17, 2010, 08:42:31 AM
Thanks for the responses thus far.  I was using the browser example as more information.  I don't need to do anything on this machine but run the plaz.  I would however like to watch it remotely.
I was under the impressions that people were using webcams for edge finding... I just want to broadcast mine across the network.
Post by: derekbpcnc on December 17, 2010, 12:55:28 PM
My Pc has a minimum install.
No network, IE browser, no apps, virus software, other than Mach etc = no running problems.
Most industrial controllers don't have anything other than whats needed to run the machine...for good reason.
If you want a web cam to watch the machine, it would be best to plase a second PC next to your machine and have all the "none mach" stuf running on the other machine.
ATB
Derek
Post by: andrewm on December 17, 2010, 01:28:26 PM
If the webcam is USB based and you're office isn't to far away you could always just use a USB extender cable or two and hook it up to you're office machine. Or you can purchase a wireless webcam and run it from you're office with the Cam setup near the machine.
Just a thought, might be a cheaper way to do it if you wish to not setup a second computer
Post by: derekbpcnc on December 17, 2010, 01:47:06 PM
Good idea, or use an IP web cam over ethernet or one of the wifi cams.
ATB
Derek
