Mach Discussion => General Mach Discussion => Topic started by: fixittt on December 10, 2010, 03:23:33 PM
Title: Having an issue with arcs O ring pocket code.
Post by: fixittt on December 10, 2010, 03:23:33 PM
We are having an issue with this g code.  It works on a HAAS machine fine.
Problem is, its suppost to cut an o ring grove .5 inchs in diameter.  But its giving us a 1 inch or better pocket.
Any ideas? Problems that you may see?
Title: Re: Having an issue with arcs O ring pocket code.
Post by: Hood on December 10, 2010, 03:40:31 PM
Works fine here, think you may have the IJ mode set wrong, change it from General Config page from Abs to Inc.
Post by: fixittt on December 10, 2010, 04:01:52 PM
That did it!  Thanks!  I dont deal much with arc fitted toolpath with what I do........  THANKS BUNCHES!
Post by: Hood on December 10, 2010, 04:19:37 PM
Really your code should define the mode, if you had a G91.1 at the beginning of the code it would have run fine even though Mach was set to Abs (G90.1) the code would have overridden Machs default.
Post by: fixittt on December 10, 2010, 04:57:27 PM
I will pass that info along to the end user,  Thank you!  I dont know enough about arc toolpath yet.
Post by: Hood on December 10, 2010, 04:59:37 PM
You probably know more than me :)
