Mach Discussion => General Mach Discussion => Topic started by: technicrdd on November 07, 2006, 01:26:41 PM
Am having trouble getting the setover of a .250 ball end cutter setover (0.125"). I want the setover to be around 0.050". Can not tell where or the settings or offsets are to be used. Can I do this in Mach2 or must I go back to the BobCad program to do the reset to a smaller setover, Help anyone!
That is a setting some ware in BobCam. I would also suggest that you update to the latest version of mach 3. Mach 2 isn't supported any more and most people are using 3.
Chad
You will need to set the stepover in BobCad... I can't help you do that as i don't run it :(
