Third party software and hardware support forums. => PoKeys => Topic started by: Ignacio Plass on December 02, 2010, 11:11:44 AM
Title: Pokeys + LCD + 3MPG + Joysti + botones
Post by: Ignacio Plass on December 02, 2010, 11:11:44 AM
hello.
I'm new, from Spain,
I have a router running Mach3 and Pokeis55, I have a 4x20 character LCD, but I can not see the values of the DRO, XYZ and A. This solved this?.
Gracias
Title: Re: Pokeys + LCD + 3MPG + Joysti + botones
Post by: borisz on December 02, 2010, 11:47:49 AM
Mach plugin for PoKeys  on www.poscope.com
Read manual in plugin.
regards
Boris
Post by: Ignacio Plass on December 02, 2010, 03:42:34 PM
hello.
comfiguracion LCD's work,
ok but how to operate the lever potentiometers. is also the progracion macropump and VB, or directly by the pokesys55,
gracias
someone who has developed this before? There are examples, photographs, etc. .. of work?
Gracias desde Barcelona
Post by: borisz on December 02, 2010, 04:08:21 PM
Just use PoPendant settings in plugin and all hould be configured
regards
Boris
Post by: Ignacio Plass on December 03, 2010, 11:06:17 AM
hello.
can prevent flickering of the LCD, used by the Pokeys?
 Gracias
Post by: Nigrofer on January 06, 2011, 06:31:28 PM
hi from spain
I am waiting my pokeys
Espero lo hayas podido configurar
Saludos
Post by: Ignacio Plass on January 07, 2011, 02:58:24 PM
hello.
 continuous creation of a control panel.
 45 keys.
 3 MPG.
 1 display.
 1 4-axis lever
 1 touch pad.
 4 potentiometers.
I need help.
 the display works.
 the 3 MPG. work.
 but I need to program the keys on the multiplexer.
 and support for the 4 analog inputs
y para el español, donde estas, tienes alguna idea de mi problema?
Gracias
Post by: Nigrofer on January 07, 2011, 11:28:40 PM
At the moment I haven´t it.
No me ha llegado todavía, Caripean, cuando lo tenga tengo que configurarlo y ya te contaré como me va.
Regards
Post by: Ignacio Plass on January 18, 2011, 11:01:36 AM
hello.
 I configured the three MPG and works .. 47-key keypad with 10x5 matrix, and it works. LCD works with Macropump system.
 I do not understand the analog inputs.
 My intention is to control 4 functions;
 1 FRO
 2 speed spindle
 3 MPG feed rate
 4 Slow Jog Rate
 someone can show examples of use and control of the analog inputs?
 Gracias
Post by: poppabear on January 19, 2011, 12:05:32 AM
when you set the 1st four, analogs (starting at lowest pin number), for analog in, then if you will look at the OEM "PoKeys.set" screen set, on the PoKeys page in that screen set, you will see 4 analog input DROS that should change value as you turn yoru pots. NOTE: READ the Flash HELP by pushing the HELP button in the PK config dialog of the plugin!!!
then in Brains, or Macro pump, your choice.  Map the analog UserDROs to the funcs you want.
See "Brains users guide" in the member docs section further down. in this forum......
scott
Post by: Ignacio Plass on January 19, 2011, 01:23:58 AM
hello.
 good response.
 I searched the forum pokeys solution, and are Brian Mach,
 now to investigate.
 thanks
Post by: Ignacio Plass on February 19, 2011, 03:19:12 PM
hello.
 continuing my work as I have a hard finish.
 here are some photos.
Post by: Ignacio Plass on February 19, 2011, 03:22:32 PM
the final aspect of the machine
Post by: ostie01 on February 19, 2011, 05:19:12 PM
This is a very nice setup you have my friend.
Could you tell us about your mill.
Never seen one like that before.
Jeff
Post by: Ignacio Plass on February 20, 2011, 03:48:15 AM
gracias Jeff.
Is a Mill Wabeco 1410 hf
https://www.wabeco-remscheid.de/index.php?cat=c16010_F1410-LF---F1410-LF-hs.html&subpage=basics&picture=2
modified for the CNC control.
 ball screws. and 6-axis meter. HEIDENHAIN.
 with an accuracy of 5 milli of a millimeter.
 machinery is a marvelous.
 is the second machinery I have of this brand are very good German quality.
 and many hours of work and lot of love
From Barcelona Spain,
 Ignacio
Post by: Ignacio Plass on February 20, 2011, 04:58:54 AM
hello, one video of my mill
http://www.youtube.com/watch?v=gYh70ZxjiS8
Post by: arturod on February 21, 2011, 05:40:21 AM
Ignacio,
Nice job.  Did you wire all the electronics or did you use our expansion boards for this?
Arturo Duncan
http://cnc4pc.com
Post by: Ignacio Plass on February 21, 2011, 06:00:41 AM
hello.
 all handmade by me.
 I only bought the pokesys. wiring and circuit boards I have designed myself. HEIDENHAIN keys are original. LCD is bought on Ebay.
 I'm still configuring the software for analog inputs and buttons, to be run on a screen of Mach3 which I designed with Screen4.
 thanks for the question.
