Mach Discussion => General Mach Discussion => Topic started by: kkquek on November 26, 2010, 06:46:38 AM
Title: new version mach3 no dxfimport?
Post by: kkquek on November 26, 2010, 06:46:38 AM
I using old version mach3 1.84 with the dxfimport, but now try the new version 3.04.40 only got Lazycam import, can i copy the old version dxfimport.exe to replace the Lazycam? because I need very simple convert dxf to g only, please help?
Title: Re: new version mach3 no dxfimport?
Post by: Tweakie.CNC on November 26, 2010, 07:02:21 AM
I think the only way to keep the direct DXF import is to keep using the earlier version of Mach.
However I can't see any reason why you can't have both versions on the same PC and then use which ever version you choose.
Post by: kkquek on November 26, 2010, 07:12:06 AM
thank a lot
Post by: Hood on November 26, 2010, 10:27:50 AM
If you do as Tweakie suggests make sure you install the older version to a different directory and Don't install the driver or you will overwrite the newer driver and will likely have problems.
