Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: srracer on November 14, 2010, 12:51:00 PM
Title: Rectangle cutout - What am I doing wrong? (or, is this a bug?)
Post by: srracer on November 14, 2010, 12:51:00 PM
Just purchased the Newfangled wizard and in general I'm pleased with it..
One thing that's been a bit of a nuissance, though, is the rectangle cutout wizard.
After crashing my Mach 3 several times while I waited for it to finish (after pressing make code), I realized that if I hit cancel and exit, I would get back to the Mach 3 screen and whatever code it had managed to finish would be posted..
The problem was that the wizard was starting at the correct Z and then going UP, so it never reached the correct depth (obviously) and wrote code that ran pass after pass raising the Z ad infinitum. (this happened no matter what combination of negative signs I tried out in front of both the step depth and final depth numbers)
After some debugging, I found that the problem went away if the step depth was *less* than the final depth, but if it was the same or more, then endless loop ensued.
Thanks!
-Chris
Title: Re: Rectangle cutout - What am I doing wrong? (or, is this a bug?)
Post by: srracer on November 19, 2010, 09:39:07 AM
Nobody has any feedback?
So should I understand that the NFS wizards will not allow me to perform any of the profile cuts in a single pass without me editing the code?
-Chris
Post by: BR549 on November 19, 2010, 11:33:11 AM
IF you command a G1 Z-1 move from the mdi line which way does the tool go, up or down?
Post by: srracer on November 19, 2010, 12:42:23 PM
If Z was at 0, it would go down.
Chris
Post by: Ron Ginger on November 19, 2010, 12:59:53 PM
Sorry for the delay in getting to this- I missed your original post.
It looks like you have found a bug. The preview code works OK, but the post does not. Ill get it fixed and have a new  version out soon.
Post by: Ron Ginger on November 19, 2010, 01:51:35 PM
OK, I found it and fixed it. See the new topic on V2.85
Post by: srracer on November 19, 2010, 02:24:57 PM
Thanks Ron!  I'm glad to know I wasn't going crazy.
-Chris
