Mach Discussion => General Mach Discussion => Topic started by: coke_e on November 04, 2010, 10:49:00 PM
Title: Need help with Bridgeport Series One CNC Retro Fit
Post by: coke_e on November 04, 2010, 10:49:00 PM
I started the conversion from original set up to Mach 3 with Gecko drives in October 2009.  Fast run down of changes: break out board from Bob Campbell, Windows XP Pro, stripped out old and replaced with new power supply and rewired everything, and a new computer.
Problem: X and Y axis has intermittent bumping and losing steps randomly. I have read a lot of the posts concerning lost steps and have tried many of the solutions offered with no luck. Motor tuning will run without any problems as high as 102 IPM but I can not get the mill to perform without losing steps as far down as 2 IPM which is unacceptable for a rapid rate or a G0 function. I have spent hours reading posts of other Bridgeport posts that only get 50-60 IPM on rapids which would be fine with me if I could get that without missing steps.
Any and all suggestions would be most welcome as I am at my wits end. Trying to keep post short but rebuilt  ball screws, replaced steppers (NEMA 42) and drive. There is a lot more I have tried, if you need more information on what else was done in order to help me please let me know.  Basically just about everything has been replaced with new.
Thanks in advance
Coke  :-\
Title: Re: Need help with Bridgeport Series One CNC Retro Fit
Post by: BR549 on November 04, 2010, 11:00:48 PM
Start with the basics.Power supply size and voltage, drives model ampsettings, stepper make model. What are the tuning parameters, Vel, accel.
Are the drives direct drive to the screws or reduction.
WHen you say the drives tune ok up to 100 ipm, how are you testing them????
Post by: coke_e on November 04, 2010, 11:17:47 PM
Power supply size and voltage: 60 volt DC; Drives: Gecko 201; AMP settings 6 amps; Stepper make and model: Z and Y axis are original NEMA 42, X axis has a new Kelling NEMA 40 tooth; Tuning: Currently 55 VEL acceleration is set a 1.75; Drives are belt 1 to 1 5 tpi lead; Drive test: with the tune feature in Mach and the settings for X and Z is 105 acceleration of 5 and the Y will only do 102 ipm with the same settings. I realize that is Mach running flat out but the motors all run smooth and quiet, the problem comes in when I slow down to run a program at slower speeds.
Thanks for your rapid response and willingness to help.
Post by: BR549 on November 04, 2010, 11:51:48 PM
POwer supply size in amps??  IF the capacity is too low when all drives run at the same time the drives may not prove enough power to the motors and may loose steps.
How do you have the drives setup do you use micro stepping?? Large steppers suffer from mid range resonance microstepping helps with that.
Post by: Hood on November 05, 2010, 03:12:10 AM
My Bridgeport is a UK version of the Boss 6, in other words a Boss 6.1. It has metric ballscrews (5mm pitch) and gearing of 2.5:1 as standard and  I use G201/G202 and have Nema 34 916 ozin steppers. I can get 2500mm/min (100IPM) with Accel of 40mm/s/s but I have chosen to reduce the Vel to 2200mm/min and can now get the Accel to 120mm/s/s.
There may be several issues with your mill, first is the bigger frame motors may be holding things back a bit, however you should still get better performance than you are. Velocity may be helped slightly by getting a slightly higher DC voltage, I am using 77 VDC
As Terry has mentioned your power supply may not have enough wattage for running more than one motor at a time.
 If you have not done so already run the driver test to see what  it looks like and if you have the kernel set in Mach to higher than you need try reducing it.
Post by: coke_e on November 06, 2010, 04:31:33 PM
Terry, Hood    What I have is 1970 Bridgeport Series 1 Cnc updated to BOSS 5
                     I installed a AN TEK 800VA Toroidal Transformer 10 Amp and built the rest of the power supply from parts
                     The original steppers are Superior steppers (90 VDC 8Amps)
                     I replaced one with a Kelling KL42H2150-42-8B
                     All 3 drives are Gecko 201 they are set microstepping the way I read the set up sheet
                     Sound Logic BOB Rev 1.9 (Bob Campbell has been a grate help)
                     Added a Sumitomo VFD and a sound Logic inter face board
                     Current motor setup
                     Steps Per            Velocity                Acceleration           Step Pulse               Dir Pulse
                        10000                70.0                       2                         5                          5
I run a progran to make a 6" square with a 1.5 pause at each corner as to read indicator before next axis move, it misses steps at all speeds worst at 31 IPM.
Coke
Post by: Hood on November 06, 2010, 04:43:08 PM
As I said previously your Nema 42 motors may be the problem and looking at the specs of them it could well be that. The G201 says "Motor winding inductance should be 500uH or greater, but generally no more than 7mH." and from the motor specs on Keling site it says your motors range between 16mH and 64mH. Might be worth emailing or calling Gecko to see what they say.
Post by: BR549 on November 06, 2010, 04:51:48 PM
Well if you have the drives set to max6 amps and you have 3 drives running that would be 18amps total.
So you may have a problem in a worse case senario EVEN with only 2 drives active at a time as that exceeds your power supply.
IF you only run 1 axis back and forth as fast as they go does it loose steps????
Just a thought, (;-) TP
Post by: coke_e on November 06, 2010, 04:59:11 PM
Terry,
I don't think it loses any steps at high speed. It runs very smooth in motor tuning. I will set the speed up on the program and try that later tonight.
Thanks Coke
Post by: HimyKabibble on November 06, 2010, 09:14:24 PM
                     Current motor setup
                        10000                70.0                       2                         5                          5
Coke
The power supply for stepper motors should be sized at roughly 70% of the total rated current of the motors.  So, if you're using Geckos set for 6A, and you have three motors, the supply should be rated for at least 18 * 0.7 = 12.6A continuous.  AND, you must have sufficient capacitance in the filter as well.  For 3 6A motors, you should have probably on the order of 20,000-30,000uF of filtering.
Post by: coke_e on November 06, 2010, 09:27:44 PM
Thanks Ray for the input. I have 33000uF and the problem is still there. I have emailed Gecko for more advice on these NEMA 42 steppers. :-\
Coke
Post by: BR549 on November 06, 2010, 10:32:04 PM
WHat is the voltage output of the power supply with the system idling no movement?
How about with XY running a zig zag pattern?
Have you tried setting up the drivers for the full 7amp output ?
Post by: RICH on November 06, 2010, 11:04:27 PM
My controller consists of  four Gecko 201's and my power supply is 30 amps at 36 volts FWTW. The filtering can be more, but, not enough is not good. As already stated proper amperage  is required.
A few tell tale signs are as follows.
IF the amps are too low the steppers won't move, if the amps are border line they will skip, if the amps are too high for the stepper
they will work fine until they get hot and then they can act very strange and unreliably. I get reminded of this since i switch different setting resistors depending on what machine my controller is used for.
You can lower amp requirements depending on how the motors are wired ( if its possible), but, then that's a trade off of stepper preformance.
But the 10 amp supply may still be marginal.
Do contact Gecko about the inductance isssue Hood brought up and reply back on what they said.
Post by: RICH on November 06, 2010, 11:16:03 PM
There is a jumper block on the drive  ( need to remove the cover ) and there is a jumper that is specific to size 42 motors that should be in place.
Post by: BR549 on November 06, 2010, 11:38:39 PM
NOW there is an interesting idea HOW have you got the stock steppers wired.
If memory serves me there were several options depending on which motor BP used.
Post by: coke_e on November 08, 2010, 02:44:52 PM
BR549,
Post by: MachineMaster on November 08, 2010, 07:29:27 PM
The Bridgeport steppers can be very touchy about step pulse smoothness. You may have to go to a "Smooth Stepper".
Post by: coke_e on November 08, 2010, 10:35:50 PM
BR549,
I don't know what happend to the rest of my last post but here is is again. Steppers are wired parallel the voltage reads 58.6 VDC at idle and around 58.3 or so at 70 IPM. Just for thought, Bridgeport set the steppers on BOSS 5 at 1/2 step pulse which ment that each pulse was .0005 of movement. This may be part of the reason that big NEMA 42 don't like micro steeping. (10000 pulse per inch is a lot of pulses)  I have emailed GECKO for some ansers.
Coke
Post by: MachineMaster on November 09, 2010, 12:02:10 PM
All of the Bridgeport steppers are full step. The ones that can get .0005 movement have a 2:1 belt drive. Those were usually a BOSS 6 or a series II mill.
