Mach Discussion => General Mach Discussion => Topic started by: rrc1962 on November 04, 2010, 09:54:50 PM
Hi All...
Is there a way to load a g-code program from another program. I have an app written in VB.net that writes g-code to a file. I'd like to have that file load automatically into mach after it is generated. Is there a way to do this without using the Mach API?
I don't know how to do it but obviously there is a way because LazyCam does just that.
I'd guess that LazyCam, being a mach plug-in, uses the mach SDK. I can't use the SDK. I don't have the right version of visual Studio. I've tried the VS2008 plug-in a number of times but can't get anything beyond the sample apps that it creates automatically to run. I'm wondering is using a COM connection to Mach would work and if so, how to go about doing it.
