Mach Discussion => General Mach Discussion => Topic started by: stirling on October 24, 2010, 05:28:30 AM
Title: Mach & windows7
Post by: stirling on October 24, 2010, 05:28:30 AM
Don't know if I've missed it somewhere but what's the state of play re: windows 7 and Mach?
Ian
Title: Re: Mach & windows7
Post by: ger21 on October 24, 2010, 05:48:02 AM
There are some threads in the  Mach and Windows Vista forum. Appears to run fine in 7.
Post by: stirling on October 24, 2010, 06:10:00 AM
Thanks Gerry
Post by: kcib on October 24, 2010, 06:46:21 AM
Have been running Windows 7 for some 9 months without any problems whatsoever ,
Post by: Jeff_Birt on October 24, 2010, 10:18:23 AM
If you want to use the parallel port driver stick with the 32bit version of Win7. The parallel port driver will not run on a 64bit OS. If you want to use a SmoothStepper or other external motion control board than the 64bit version is fine. (I know the SS works fine on Win7-64.)
Post by: stirling on October 24, 2010, 10:24:58 AM
Thanks Alan
Thanks Jeff - It'll have to be the PP driver because this is a plasma setup with THC so as I understand it the SS is a non-runner - is that correct?
Post by: Jeff_Birt on October 24, 2010, 10:40:37 AM
Right. The SS does not do THC at this time.
