Mach Discussion => General Mach Discussion => Topic started by: MachineMaster on October 23, 2010, 05:43:38 PM
Title: When Homing, Z does not back off switch
Post by: MachineMaster on October 23, 2010, 05:43:38 PM
I am running Mach3 R3.042.040. I have switches on X, Y and Z for homing. I am using parallel port pin 11 for X home, pin 12 for Y home and pin 13 for Z home.
When I hit the "Home" key Z goes up until the Z home switch goes from high to low and stops. Then Y goes to the Y home switch. When the Y switch goes low Y reverses until the Y switch goes high and stops. Then X goes to the X home switch. When the X switch goes low X reverses until the X switch goes high and stops.
What is causing the Z to just stop on the Z home switch and not back off?
Title: Re: When Homing, Z does not back off switch
Post by: Hood on October 23, 2010, 05:59:42 PM
Do the machine zero coords for the Z zero?
Post by: angel tech on October 23, 2010, 07:11:56 PM
do you have anything else set on pin 13
Post by: Greolt on October 23, 2010, 07:22:27 PM
Once you have checked out the two suggestions above then try a hefty debounce interval.
Greg
Post by: MachineMaster on October 23, 2010, 08:49:44 PM
Z coords do set to zero. I want to use the same switch for Z++ limit and that is set to 13 but it is not active as yet.
I will try the de-bounce.
Post by: MachineMaster on October 23, 2010, 09:28:48 PM
A de-bounce of 200 fixed the problem. Now I have both homing and limits on the same switch. I think I will also set soft limits.
Thank you
