Mach Discussion => General Mach Discussion => Topic started by: Morte on October 21, 2010, 08:49:26 AM
Hi all,
I installed mach3 on cleaned PC with windows XP and few drivers installed only. Then I started to work, in few minutes the Mach froze. Through Ctrl+Alt+Del I exited Mach and tried again few times with the same problem. I restarted PC and machine and reinstalled the Mach.
Now Mach is not freezing but sometimes (may be every 5-15 minutes of work) machine stops working and error message on the picture appears. After restart of machine connection and Mach, all is ok for about 5-15 minutes of work, then it fails again.
On other PC I didn't have the same problem, it was just freezing sometimes for few seconds and worked again but i think, that it was happening because of a low performance of PC and applications running in background. The setup of Mach was absolutely same like the one I'm using now.
I'm quite helpless and I will welcome each idea.
Thank You
Please see: http://www.soigeneris.com/Document/Installing_and_Configuring_the_SmoothStepper.pdf (http://www.soigeneris.com/Document/Installing_and_Configuring_the_SmoothStepper.pdf) . Also, what to you mean by 'cleaned pc'? It is much better to start out with a fresh, NON-ACPI, Windows installation. Then follow the tips in the document above. Also, posting this in the SmoothStepper section of this forum might generate more responses.
Perhaps a moderator will move it to the SS section of the forum?
