Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: turmite on January 19, 2006, 11:41:53 AM
Title: Array wizard?
Post by: turmite on January 19, 2006, 11:41:53 AM
Hi Brian,
I have not tried the wizards yet as I am still using Mach2. I'm in the beginning stages to make the change and one option I think would be neat, and you may already have it, is an array wizard. I know this can be done in gcode somehow, but I started out with a system that had a fill in the block array wizard that was so quick it was just a pleasure to use.
Off topic but I thought you might enjoy it. I need a wizard that can read my mind and get the machine to produce what I see in my mind! I make gunstocks and I can see what I want, but to get it into Rhino and then to the machine is a different story! It never looks like what I see! So when you get the time do a "gunstock wizard" ;D
Mike
Title: Re: Array wizard?
Post by: Brian Barker on January 19, 2006, 01:25:11 PM
There is an Array wizard that Art made, I have not used it but I think we can figure it out <G>
The wizard to read your mind... hmmmm what are you tinking about using to get the data out of your head??? :)
Post by: turmite on January 20, 2006, 06:43:36 PM
Brian it is hard to extract from a vacuum! The array will do for now! ;)
Mike
