Mach Discussion => General Mach Discussion => Topic started by: uirobot on September 13, 2010, 12:58:12 AM
Title: Can Mach3 work on stepper driver with RS232 interface
Post by: uirobot on September 13, 2010, 12:58:12 AM
Someone told me that Mach3 just can work with parallel port stepper driver, is it right?
If I have a stepper controller with RS232 interface or CANBus, how could use Mach3 software? Thanks
Title: Re: Can Mach3 work on stepper driver with RS232 interface
Post by: manmeran on September 13, 2010, 02:06:12 AM
your answer is NO
mach can work with parallel and another hardware( for example :SS or Galil or Kflop ...)
Amir
Post by: uirobot on September 13, 2010, 03:13:15 AM
Thanks! But how could Mach3 work with XYZ or more than three-axis serveral parallel port drives?
Post by: manmeran on September 13, 2010, 03:14:28 AM
you can read manual for start.
Amir
Post by: stirling on September 13, 2010, 05:14:18 AM
Only two parallel port pins are needed for each motor driver. A "standard" parallel port has 5 inputs and 13 outputs. More than enough to run 3 motors, spindle on/off, dust exctractor, limit switches, home switches etc.
Post by: uirobot on April 25, 2011, 04:20:29 AM
With many thanks to Stirling, that's really helpful to me a newbie
