Mach Discussion => General Mach Discussion => Topic started by: brouser1 on August 26, 2010, 12:48:42 AM
Hello
I am hoping someone can help me setup or just get in the ballpark with my cut profiles. This profile is for cutting 3/8" steel, I have a Hypertherm Powermax 45 w/ Machine torch & Z floating axis.
I can fill out a few of the options:
Tip Volt Preset 120
THC Delay 1 Is 1 sec too slow or not slow enough?
Tip Saver % *What is a good starting point?
Arc OK Current *What is a good starting point?
Cut Current 45
Span Gap 4
Upper Fault Limit *What is a good starting point?
Lower Fault Limit *What is a good starting point?
Current Tolerance % *What is a good starting point?
Any and all info is greatly appreciated.
