Mach Discussion => VB and the development of wizards => Topic started by: tantan on August 16, 2010, 06:13:24 AM
Title: macro when starting mach or after reset
Post by: tantan on August 16, 2010, 06:13:24 AM
hi all.
i want to run a macro after mach has been started. how should that be done,
thanks for your answer.
antoine
the neterlands
Title: Re: macro when starting mach or after reset
Post by: BR549 on August 16, 2010, 09:32:05 AM
Reference the macro as a Mcode in the initializaton section in Gen Config.
Post by: tantan on August 16, 2010, 09:44:48 AM
hi,
thanks for your reply, but can you give me an example: my initialisation string now only has "G80" in it.  the name of the macro is test.m1s, should i make my initialisation string "G80 test.m1s"
thanks,
antoine
Post by: BR549 on August 16, 2010, 10:12:11 AM
You need to rename your Macro AS say M300 and place it in the macro directory. Then the string would read "G80 M300"
Post by: tantan on August 16, 2010, 11:15:23 AM
hi
Thanks, Works Perfect!!!!  :)
Antoine
