Mach Discussion => General Mach Discussion => Topic started by: hharley on August 02, 2010, 01:43:40 PM
I had Mach 3 installed and leaning it. I could move the motors at will and do the examples . I had to reload the Mach 3 and sence then having motor control problem. No matter what arrow key i chose . It moves the X to the left only . I have checked Pin settings and they are correst. Im useing wondows XP . I have reloaded the Mach3 program and LPT driver 3 times same results
Check to make sure you have the Dir port set correctly for that axis, if that is not the problem then it sounds like you have a loose Dir wire.
I made some changes I turned on not only XY&Z but turn on AB&C and the motors started working right . I still have to have estop turned on or i cant reset ,even with machine hooked up and on, But at least the axes are all working
Can you attach your xml please.
I have solved the problem contacted Zenbot for the pin codes They had a Mach 3 configuration file . I loaded it in Mach 3 file and all working well TY
Good to hear :)
