Mach Discussion => General Mach Discussion => Topic started by: SScnc on July 22, 2010, 08:48:10 AM
Why do none of the lathe screen sets available have the ability to change the rapid speed. Only Feed Rate and Jog%, am I missing something here? I'd like to have what the Mill screen has with the slider. I don't really like going at full speed when running a part for the first time. Help?
~Scott
Two things you can do, first is make sure on General Config page that rapid is locked to FRO, that way when you reduce the FRO by 50%, or whatever, the rapid will also be reduced by that amount.
If you prefer total control then you can use one of the screen designer programmes and add a slider for Rapid to your screen.
